Wideband on PRA Euro ECU.
menfou
Post by menfou »
Hello,
I would like to put a Wideband on my PRA ECU, but where can I buy it and what modification I need to do?
I have always 14.7 for A/F with my Civic Type R and the narrowband.
alanb
Post by alanb »
menfou
Post by menfou »
Hello alanb
I know you have this product, but me I want only use K-PRO and not a external product.
I think it's possible to use a wideband with PRA ECU but how?
You cannot get the PRA ecu to work like the other K-series ecus as it does not have the correct componnents inside the ecu. You may wan tto contact Guy at CPL for the specifics.
alanb
Post by alanb »
theres the option to replace the stock narrowband and wire the gray wire with a resistor into the PRA ecu so fooling it into a narrowband signal like stock
the other output is to a display and or logger for tru wideband reporting
as spunkster says the PRa ecu is not wired to accept wideband input
menfou
Post by menfou »
alanb wrote:theres the option to replace the stock narrowband and wire the gray wire with a resistor into the PRA ecu so fooling it into a narrowband signal like stock
Thank you Alanb,
I will contact Guy or Doug to know where I need to put the resistor ;)
