Kpro v2 flashmemory problem
pcvirus
Post by pcvirus »
Hi
I have upload problen
I applied all the parameters
I use current version please help
K pro sn 1455
Board serial 05005945
Re: Kpro v2 flashmemory problem
That is a version 1 K-Pro and does not have on-board datalogging.
If you wish to upgrade to the version 4, details and the form can be found at: https://hondata.com/downloads/kpro4_upgrade_form.pdf
pcvirus
Post by pcvirus »
Is it normal ?
Flash memory warning ?
yes, as it does not have flash memory.
pcvirus
Post by pcvirus »
Problem is not registered
I cant upload calibration sir
pcvirus
Post by pcvirus »
I can upload v 4.4.6
But new version i cant upload
I have registered warning
That K-Pro cannot be registered as it does not have that capability.
The software is out of date, and you must use the current software from our website: https://hondata.com/software?route=info ... nformation
pcvirus
Post by pcvirus »
It works with the old version, but with the new version, the screen is not active and cannot upload.
The latest version does not allow me to install
gives registration warning
Using the current version of software, with everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
