Hi, I would like to see if I could get this base map revised/adjusted so that this engine can operate safely before my tune. Thanks
It is a B20Vtec.
B20B Block
GSR head.
YCP type r pistons
ARP studs
basically all stock except for YCP pistons.
skunk2 pro manifold and 70MM TB
550cc bosch ev6 injectors
Full 2.5 exhaust and air intake
its on a 2000 civic EK sedan with a civic type r transmission and LS 5th gear.
ECU is a P28.
I started a p30 base map with some adjustments to fuel and timing but per the attached Log, I would like some adjustments, fine tune the A/F ratios and fuel, as well as vtec, it felt very weak when it engaged and I'm wondering if I had it set too high and with incorrect parameters.
Anyways if you can make this map better than what it is I would highly appreciate it.
Urgent!Base map revision before tune.
Marcsantana7
- CalibratEd
- Contact:
Re: Urgent!Base map revision before tune.
Did you still need help with this? Are you running a wideband? Why are you modifying the tune if you plan to get it tuned properly? Perhaps you can reach out to your tuner for a base map.
- Ed
- Ed
Instagram: calibrated.tuning
