Kpro/flex fuel error code P0176
harris
Post by harris »
Hello Everyone,
Have a little issue here and looking for some help...
I am running kpro4 with sos flex fuel kit(Continental sensor) on my 04 S2K
When E85 in tank i am getting error code P0176. Double check wiring connections already and everything seems to be right. Also replace the actual sensor with brand new one! Contacted Hondata but they couldn't help me...
Does anyone have any idea what can this be and how to fix it???
Thank you!
Re: Kpro/flex fuel error code P0176
Please see info in the help file for this code: https://hondata.com/help/kmanager/dtc_e ... tsub=P0176
harris
Post by harris »
I check voltage on cranking and was little ove 10 so I do not think is about low voltage. How can I check the electrical noise?
You would have to use an oscilloscope.
harris
Post by harris »
OK i will check it with an oscilloscope... What am i doing next? How do i fix the frequency being out of range?
You will have to find the cause and then correct that.
