Error p2279 k24z3
Posted: Thu Nov 16, 2023 1:26 pm
by VIadimirZ
Good afternoon. After installing a wastegate on the intake manifold of the TVS1320 compressor k24z3, error p2279 constantly appears. Is it possible to make a window in the menu to disable it? Thank you
Re: Error p2279 k24z3
Posted: Thu Nov 16, 2023 1:32 pm
by VIadimirZ
TSX 2012 US АT
Posted: Thu Nov 16, 2023 4:18 pm
Is it venting to atmosphere?
Posted: Thu Nov 16, 2023 10:41 pm
by VIadimirZ
Sure
I would upload a photo, but I don’t understand how to do it :)
PS You did it once for our other project disabling p0128
Posted: Fri Nov 17, 2023 10:09 am
It cannot vent to atmosphere as it will alter the amount of air that the AFM has measured already.
Posted: Fri Nov 17, 2023 11:41 am
by VIadimirZ
The motor operates using MAP. The MAP sensor is located after the wastegate. MAF is only needed for automatic transmission
Posted: Fri Nov 17, 2023 12:32 pm
Our software engineers will put this in the next release for you to try. There is no guaranty it will work.
Posted: Fri Nov 17, 2023 1:36 pm
by VIadimirZ
Thank you very much. I'll test it and report back
Posted: Sun Nov 26, 2023 4:30 pm
by antisocial
VIadimirZ wrote: Thu Nov 16, 2023 1:26 pm
Out of curiosity, was that code present before the wastegate modification?
Is this a MercRacing Supercharger setup?
Reason I ask is that I have one, and plan to install it soon.
Posted: Tue Nov 28, 2023 3:30 am
by VIadimirZ
This is an external Tial MV-S 38 wastegate. It has nothing to do with the compressor itself
The previous version of the engine with the Merc Racing TVS900 compressor had no wastegate at all. The engine was set to a boost of 8,5 in summer and 11,5 in winter (the air temperature is lower - the boost from the compressor becomes higher). The same version of the engine with Merc Racing TVS1320 boost 14,5 in summer and 19 psi in winter, which is a lot. That's why a wastegate was installed
Posted: Fri Dec 08, 2023 3:35 pm
by VIadimirZ
Everything works perfectly. Thank you
Posted: Mon Dec 18, 2023 5:16 am
by antisocial
Can we add this feature to the 2011-2014 US Spec MT as well?
Posted: Mon Dec 18, 2023 11:05 am
It has been put on the list.
