Idle Lambda cannot be changed from 7.35
fulken
Post by fulken »
Why the idle lambda is always set to 7.35? I changed to a different value (14.7), but it automatically goes back to 7.35.
How can I set it to 14.7? Is this a bug?
Version 4.5.6.0
Re: Idle Lambda cannot be changed from 7.35
This is a PRA calibraiton and cannot use a factory wideband and only works with a narrowband o2 sensor. The value in question is not used.
fulken
Post by fulken »
Spunkster wrote: Mon Nov 20, 2023 11:24 am This is a PRA calibraiton and cannot use a factory wideband and only works with a narrowband o2 sensor. The value in question is not used.
Great information!
Can you add this information to the help file?
Thank you!!
Kenji
