Can't upload tune - registration required
akep
Post by akep »
tried to use this ecu and it said needed to update drivers and kpro software (from current to beta) then it said i needed to register before uploading.
same as the earlier posts but all green in info panel and otherwise everything in the software looks ok (on line, drivers installed, no locks) i even pulled the stored tune off the kpro, but not able to upload or anything.
Re: Can't upload tune - registration required
akep
Post by akep »
4.5.6
