INJ pulse width going very high
MondeCruel
Post by MondeCruel »
Hi, i had an issue with my k swap yesterday.
The car was hard to drive i had to be very gentle with the gas pedal or it shacks badly or can even go dead, so it felt like a fuel problem. Here is a small part of the datalog i made, you can see the INJ go very high for no reason and so afr going very rich and battery voltage being drawn.
My maximum inj usually is 10 or 11 at wot. What do you think ? bad injectors maybe ?
Re: INJ pulse width going very high
It looks like it may have something to do with the battery voltage dropping. The voltage also appears to be very jagged, and it should be much smoother.
MondeCruel
You are right if i compare to others my battery voltage moves a lot do you know what can cause this ?
It could be any number of things, but may be related to the grounds, or other wiring issues.
