RSX Speedometer Problems
XingRat94
Post by XingRat94 »
Hey how’s it going?
I have all functions in my car except the speedometer.
Started a thread on this over on K20a, but was not able to get to the source of my problem. I’ll post the link to it so you can see what I’ve covered so far.
Here’s what I’m working with:
2006 RSX-S
Original engine harness
02-04 type s ECU( with Kpro )
JDM K24a engine
Original trans (06 type s, Z1 )
Here is what I have confirmed working :
- All fuses are good
- CSS is selected in Kpro
- K Line is functioning
- Pin B13 VSS output has 5V signal is at the cluster
- Pin B11 Communication line at cluster has 7.14V
- All grounds at cluster are good
Cluster self diag test confirms all gauges sweeping including the Speedo. I DO have an “error” code at the end of the test though. Which I assume is the problem.
Here the k20a link :
https://www.k20a.org/threads/rsx-speedo ... 6/#replies
Any suggestions?
Thanks in advance
XingRat94
Re: RSX Speedometer Problems
Post by XingRat94 »
Was unable to edit:
Forgot to mention, while driving with Kpro open on my laptop, speed is working during a data log( on the app) The physical Speedometer is still not responding.
Also, tested the speed sensor and I have two 5V’s and a ground on the 3 wire plug.
XingRat94
Post by XingRat94 »
Trying to post a picture but not having any luck.
It’s a red chip so Kpro v3?
I have a sticker on the bottom right - “K-Pro 10838”
What error code are you getting?
XingRat94
Post by XingRat94 »
Not getting any error or CEL codes , I’m just seeing “error” on the cluster where the kilometres are typically , after I do a cluster test.
Is there a way to get a sort of a blink code from that ?
Post the calibration and a datalog made with that calibration that shows the issue.
XingRat94
Post by XingRat94 »
The car is put away for the winter now so won’t be able to get any datalogs other than idling or turning the wheels over on jackstands.
In Kpro it reads the Speed accurately. Just isn’t being translated to the physical speedometer.
Not sure how to post my calibration, I’ll try and DM it to you
Edit: unable to DM you
Hopefully this works!
K24.z1cams.oilpump.50deg.swapheader.3inexhaust.rbc.pumpgas_09.11.21.kal
Post a picture of the adapter harness you are using.
XingRat94
Post by XingRat94 »
XingRat94
Post by XingRat94 »
Still an ongoing issue for me, Spunkster any more suggestions ?
I can’t drive the car right now, due to snow. I am able to lift the wheels and get a stationary datalog if you think that would help narrow the issue ?
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
XingRat94
Post by XingRat94 »
Will take care of that tonight !
Thank you
