Questions kpro v2
jonatan riaño
Questions kpro v2
Post by jonatan riaño »
Hello, how are you all? I wanted to ask a question regarding the kpro v2 since I think it is not possible to read an 02 external sensor in a closed loop.
But can you connect an o2 sensor to some input and configure it so that you can make A/F adjustments? after a datalog? I would like to know if it is possible to adjust the mix even when in open loop making logs
CalibratEd
Re: Questions kpro v2
Post by CalibratEd »
Hello,
This might help answer your question.
viewtopic.php?t=19367
-Ed
Instagram: calibrated.tuning
jonatan riaño
But if I can register it, could I make adjustments or would the software tell me what percentages of gasoline to add or remove or would it only read the mixture?
jonatan riaño
Need resolv this questions please
You can connect it for datalogging only and cannot run it in closed loop.
jonatan riaño
Very aprecciate thanks for help
