2012 Civic SI Basemap help
NormalNermal
Post by NormalNermal »
Hello all,
I've been lurking on this forum for the past few days since my Flashpro came in. I'm extremely new to anything tuning related, but after doing some mods I wanted to make sure my car was safe/efficient to drive on one of the basemaps.
Installed mods:
RV6 2.5 in exhaust (catted)
Invidia Q300 exhaust
K&N 12-15 Civic Si Typhoon Air Intake System
Initially used the stock MAF tune and then switched to the attached tune.
I took it for a drive tonight on this tune and it felt much better, less lurching when letting off the throttle, etc. I will upload the datalog from that as well. Thank you all in advance!
NormalNermal
Re: 2012 Civic SI Basemap help
Also just had this code pop on my way to work this morning. P0139 Oxygen Sensor Circuit Slow Response. I’m not sure if this could be from a Flashpro related issue or if the O2 Sensor just needs changed.
Water
Post by Water »
Check for exhaust leaks, if there's an issue with your O2 sensor, the datalog readings for fueling may not be completely accurate.
- Brand
