please check my cal
dercanbonlyone
please check my cal
Post by dercanbonlyone »
04rsxs pray 3cams k2024 na frank.
dercanbonlyone
Re: please check my cal
Two minutes and twenty seconds in it begins to miss and slightly bog. Then really bad at 2 minutes fifty seconds.
Also I have 440 injectors and bored cylinders to 88mm. Nothing new to the tune since dynatune at speed factory but since then is now falling apart. Perhaps corrupt tune
You should take it back to the tuner and have them take a look at it.
dercanbonlyone
Unfortunately the person that originally tuned mine over at speed factory no longer works there because it was quite a while ago but they said they had my file on tune and it's the exact same one that I currently have now so it can't be that. But thanks for the reply and advice.
They may still need to take a look at things as there could be a mechanical issue.
dercanbonlyone
Ok. I'll keep trying to appeal to their better nature. I understand you guys aren't miracle workers with every answer but I still appreciate and value your input. I know nothing.
MondeCruel
Post by MondeCruel »
I watched the log, your map sensor is working ok ?
CalibratEd
Post by CalibratEd »
Double check your Intake Air Temperature sensor. Throughout the whole log it was reading 43 degrees. This value should change as the car warms up.
If possible post a part throttle log.
- Ed
Instagram: calibrated.tuning
dercanbonlyone
Yes my map was fine I tried three new ones honestly but I bought three of them they all read good. Also Aaron take temperature sensor was new but I could try another one just cuz couldn't hurt wouldn't be the first time I bought something new that was broken
dercanbonlyone
Also it's piss cold out here right now That's in the middle of the night with my hood up
CalibratEd
dercanbonlyone wrote: Wed Dec 13, 2023 4:50 pm Also it's piss cold out here right now That's in the middle of the night with my hood up
Oh ok. Post a part throttle log.
- Ed
