EK4 F1 swapped with B18C6 with Mugen Map
silverback_sp
Post by silverback_sp »
Hi all, My name is Arno and I have a very limited Honda Civic EK4 F1 edition that I just swapped with a B18C6 ( equivalent of B18c, or B18c5 )
My question is : does the P72 base map available to download is the perfect copy of the DC2 map made by Honda? I'm currently running a "Mugen" map but I'm worried about reliability and a little bit scared to ruin the motor with a bad map.
Thanks for your future help
Re: EK4 F1 swapped with B18C6 with Mugen Map
The P72 calibration is very similar to a stock B18C1 calibration. You may need to custom tune it on the dyno to get the most out of it and make sure it is running safely.
silverback_sp
Itr-stock.skl for 2001 ITR should not be better for my actual setup?
You can try it and see how it runs with it.
