KPro Analog Inputs and Graphing all over the place
Pghpunkid
Post by Pghpunkid »
Alright, I just got my car setup, and its all working. Display shows the correct values in PSI for boost, but I have an issue, and I think this is a bigger issue than just me. Let me clarify.
AEM 30-0306
0.5v-4.5v equates to 0 bar to 3.4 bar or 0psi to 50psi. For whatever reason, it HAS to be in bar for Hondata in Analog Inputs for it to work (even though you could theoretically input PSI scaling as provided from AEM, but that doesn't work). Once its setup as bar under Analog Inputs, it shows as PSI under Display? Then, once you do that and do a datalog, it shows as Voltage on the Graph? Same for my Analog Input AFR as well. So it shows 14.33bar at idle and scaled on 0-5, so I can't even see it.
Example:
AEM Boost gauge setup as bar as previously stated is required in other posts (https://hondata.com/forum/viewtopic.php?p=97662#p97662).
(Don't ask me why its in bar units but scaled as PSI, its working right now.)
This means that the Display is being shown in PSI, since 14 bar would mean ~200psi.
However, when graphing, it shows neither bar nor psi, its scaled from 0-5, which is voltage?
Am I missing something?
Here's my wiring for reference.
Re: KPro Analog Inputs and Graphing all over the place
Post the calibration used as well as datalogs made with that calibration showing the issue.
