Analog inputs not working after firmware V2.8.4
kseriescivic
Post by kseriescivic »
Opened hondata after updating to V2.8.4 firmware Dec 5th update and none of my analog input sensors are reading on the display tab or during datalogging.
Is there something I’m missing or need to do to get them to work?
Re: Analog inputs not working after firmware V2.8.4
bradheller29
Post by bradheller29 »
Also having this issue. I did "send feedback" hoping it gets resolved. Thanks.
kseriescivic
Okay I was wondering if anyone else was having this issue. Same, hopefully it gets resolved!
Jnguyen
Post by Jnguyen »
Having save issue, no readings on analogs. When does Hondata usually update firmware again ?
Please can you tell us what S300 you have. The best way would be in the S300 window, S300 tab under hardware, the hardware version and processor type. There are 6 different hardware types so knowing this will cut down the amount of time it takes to fix this.
Also it would be good to know how the analog input has been configured, and what type of datalogging you are doing.
kseriescivic
Here’s what it says under about. I’ll have to connect to the ecu tomorrow to look under the s300 tab.
Jnguyen
Post by Jnguyen »
Hondata wrote: Sun Dec 31, 2023 9:54 am Please can you tell us what S300 you have. The best way would be in the S300 window, S300 tab under hardware, the hardware version and processor type. There are 6 different hardware types so knowing this will cut down the amount of time it takes to fix this.
trying to data log oil pressure and fuel pressure, analog 1 and 2. getting voltage signal to s300 v3 but not reading on display.
DaX
Post by DaX »
I'm sure you guys are on it, but I'll also mention that I'm having this issue as well. S300V3, wired in a pressure sensor, sending to analog 1. I verified correct wiring and scaling, I am getting the correct voltage out of the sensor, but am not getting anything to show on the display or on the sensors tab.
Jnguyen
Post by Jnguyen »
DaX wrote: Tue Jan 02, 2024 1:35 pm I'm sure you guys are on it, but I'll also mention that I'm having this issue as well. S300V3, wired in a pressure sensor, sending to analog 1. I verified correct wiring and scaling, I am getting the correct voltage out of the sensor, but am not getting anything to show on the display or on the sensors tab.
Same here I get “0” values
Please, please tell us what hardware you have as outlined above. And provide a calibration if you can.
Jnguyen
Post by Jnguyen »
Here’s my hardware and processor
This should be fixed in a release of software tomorrow.
Jnguyen
Post by Jnguyen »
Spunkster wrote: Wed Jan 03, 2024 5:10 pm This should be fixed in a release of software tomorrow.
when will this new firmware be ready?
kseriescivic
Not sure if you still need this but here’s my hardware and processor
