I'd like to be able to drive normal and WOT once in awhile.
I currently have FBO:
K&N SRI v2,
1320 performance headers (...),
Invidia Q300 exhaust.
Currently running on
Datalog:
Need help with proper tune 06 Si
Re: Need help with proper tune 06 Si
I switched over to this cal and enabled AFM with Use speed/density with Minimum pressure at 70.03 kPa.
Here is another datalog that recorded 3 total knocks in KCount2 and KCount3.
Is my tune going to kill my engine?
- CalibratEd
- Contact:
I suggest you reduce the timing in the area you see knock. I also suggest you add fuel in the higher RPMS. Its running a bit leaner than I would run.
The lower ends is running fine as its using he MAF sensor and dialed in well.
- Ed
- Ed
Instagram: calibrated.tuning
