Page 1 of 2
Hondata S300 and AEM CD-7 troubleshoot
Posted: Wed Dec 27, 2023 1:30 pm
by Hondatuner_1
I’ve got everything connected correctly according to instructions but won’t transmit CAN data over to dash for some reason.
1. Hi/Lo CAN wires are connected via blue s300 LO/black-CD-7 plus white S300 Hi/clear-CD-7 wires.
2. 120k ohm resistor between Hi/Lo wires. Wires are twisted.
3. Dash is powered plus confirmed display setup configured correctly by AEM technical support.
4. Hondata parameter setting set correctly under Digital Input/Output CAN output MoTec SDL/ ADL (500 kbps)
Please help
Re: Hondata S300 and AEM CD-7 troubleshoot
Posted: Wed Dec 27, 2023 2:23 pm
by Hondatuner_1
Just noticed that accidentally ordered an 120k not 120 resistor which may be culprit but don’t know.
Posted: Thu Dec 28, 2023 5:50 pm
by Hondatuner_1
Update: new resistor 120 ohm installed. Only gear and voltage transmit.
Please help
Posted: Thu Dec 28, 2023 9:34 pm
by Hondatuner_1
Hondata help...
Posted: Fri Dec 29, 2023 12:50 pm
by Hondatuner_1
Please Spunkster need help
Posted: Fri Dec 29, 2023 2:55 pm
by kseriescivic
Relax, It’s the holidays. I’m waiting on some feedback but it won’t be until after new years.
Posted: Fri Dec 29, 2023 7:59 pm
CAN to dash is very difficult to remotely diagnose. Typical problems are CANH and CANL switched or the terminating resistors not present, or more than two terminating resistors.
Posted: Fri Dec 29, 2023 8:34 pm
by Hondatuner_1
so, 120 ohm resistor present at Hondata s300V3 harness connector prongs as AEM instructed me. However, There's resistance of 60 ohms between wires. Furthermore, I've come across a diagram photo which entails that resistor should be placed after harness connector. I doubt will make any positive difference. The fact that battery voltage and gear selector appear means it does transmit data. There's a firmware step in which somewhat confused of performing since not sure if doing it correctly. For instance when navigate to tools tab, update firmware and choose the latest date file present, my dash titles "Temp" read "Temps" and appear corrupt. As a result, don't want to retry update. Finally, agreed electronic troubleshooting is difficult over internet.
Thanks,
Alan
Posted: Fri Dec 29, 2023 9:29 pm
If the dash is receiving gear and voltage data then the CAN is working electrically. Any problem is likely to be a packet definition problem.
Posted: Fri Dec 29, 2023 10:46 pm
by Hondatuner_1
so, please need help fixing issue.
Alan
Posted: Tue Jan 02, 2024 9:47 am
by Hondatuner_1
Still need help, please.
Posted: Tue Jan 02, 2024 10:01 am
Posted: Tue Jan 02, 2024 8:07 pm
by Hondatuner_1
2.8.4.0 Build 3515, for some reason being 120 ohms instead of 60 ohms between Hi/Lo reading.
Posted: Wed Jan 03, 2024 9:53 am
by Hondatuner_1
Please reply and voltage isn’t at 60 ohms between Hi/Lo CAN wires for some reason.
Posted: Wed Jan 03, 2024 3:47 pm
