Skunk 2 CAI Tune
amontecinos
Skunk 2 CAI Tune
Hi , I installed a Skunk 2 CAI on my 2014 Honda civic si. What would be a good over all tune for the car to get a a little HP out of it if not any ? Please and thank you for your help
- CalibratEd
- Contact:
Re: Skunk 2 CAI Tune
Any Hondata base map you use will need some adjustments. Start with one with mods closes to yours and dial in the fuel and timing.
- Ed
- Ed
Instagram: calibrated.tuning
I have the same question... 9th gen civic si skunk2 CAI... will the PRL CAI base tune work till I get my exhaust on and get a proper tune or mail tune?
Thanks in advance.
Thanks in advance.
- CalibratEd
- Contact:
It should work for normal driving only once it’s dialed in. When you switch to an aftermarket intake you need to run it in speed density.Durc88 wrote: Tue Jan 16, 2024 5:08 pm I have the same question... 9th gen civic si skunk2 CAI... will the PRL CAI base tune work till I get my exhaust on and get a proper tune or mail tune?
Thanks in advance.
-Ed
To do that I just unselect AFM and select "use speed density/ MAP" under fuel table type?
- CalibratEd
- Contact:
Yes, that’s correct. When you do that it’s going to be a bit more work as now you have multiple fuel tables to tune. Sometimes it’s easier to find a calibration that’s already running in speed density and dial it in.Durc88 wrote: Tue Jan 16, 2024 5:34 pm To do that I just unselect AFM and select "use speed density/ MAP" under fuel table type?
-Ed
By any chance is the a base calibration you could suggest that runs in speed density? this is my first foray into hondata....
- CalibratEd
- Contact:
If you search on the forum there might be a few floating around. Whatever base calibration you decide to run I can help you make it run safe until you get it properly tuned. Just create your own thread.Durc88 wrote: Tue Jan 16, 2024 8:34 pm By any chance is the a base calibration you could suggest that runs in speed density? this is my first foray into hondata....
-Ed
- CalibratEd
- Contact:
