Hi,
Can anybody review my data log and calibrtation to give me pointers please,
FN2 Base Map
Re: FN2 Base Map
Hi,
Please if someone can review and point me in the right direction it would be much appreciated,
I have attached the logs and cal file,
- CalibratEd
- Contact:
Re: FN2 Base Map
The car is running a bit lean. No knock is present so that is good.
- Ed
- Ed
Instagram: calibrated.tuning
Re: FN2 Base Map
Thanks,
How would you address it? Add bit more fuel in?
- CalibratEd
- Contact:
Re: FN2 Base Map
dipsyv wrote: Wed Jan 31, 2024 11:49 am Thanks,
Yes, add fuel in the areas that show it is running lean. The o2 sensor is what is keeping you in line. When tuning the object is to reduce the amount of work the o2 sensor is doing. An approach you can use is to add about 7% fuel to all the tables. Log it again then reduce the fuel where needed. It is best to start rich than lean.
- Ed
