Ignition Maps
HaileyLove
Ignition Maps
Post by HaileyLove »
Hey all. I am trying to figure out an issue. I have a really nice build i did myself and have it running. I have a/f dialed in but i cannot advance distributor anymore. The trouble i am having is when i hit throttle it hesitates. If i full throttle it, it wants to die. btw this is an h22 in a lude. and if it matters i have a td61u distributor. If anyone wants to me to upload my map let me know. list of basics, g25-660, skunk2 pro manifold and tb. bc valvetrain, id1050x injectors. I would really like to know how to manually adjust ignition maps. Do i increase or decrease values on ignition map. and i know map 2 is for vtec. Thanks
Re: Ignition Maps
You should only adjust the timing maps when on the dyno so that you can measure the changes made and make sure it is safe.
HaileyLove
Re: Ignition Maps
so what else would be causing the delay/hesitation on throttle?
Re: Ignition Maps
It could be any number of things, especially since it does not sound like it has been professionally tuned.
