HPFP unlock code question
Jester04
Post by Jester04 »
Hello are the fuel pump unlock codes tied to the serial number of the pumps? Had a mix up on flashpro’s and the wrong one got the code uploaded to it. Have 2 sets of codes and 2 sets of pumps.
Or can I use the codes to just unlock the HPFP control regardless of which car is running either pump.
Re: HPFP unlock code question
The code is only locked to the FlashPro you assign it to and cannot be removed from the FlashPro.
Jester04
Post by Jester04 »
Yeah that is fine I have 2 sets of codes and 2 pumps. Just wanted to know if there won’t be issues if I use the other code in the other flashpro because of the serial number discrepancy from the codes.
