high comrpession f23 base map?setup help
destroyo
Post by destroyo »
hello all I am somewhat new to all the hondata tuning cant find any N/A base maps for f22 or f23 , I have a 99 accord, s300, f23a
Build specs: f23a with ks tuned rods arp rod bolts and head studs, weisco pistons bored slightly , about 12:1 compression, stock valves, ported head ,intake , and throttle body , custom grind cam with adjustable gear , Hunter tuned 1000cc injectors , planning to setup flex fuel sensor but will run car on e85 just need to figure out some sort of base tune to get it running a ton of time and work into this build any help would be greatly appreciated still trying to figure out where to wire the wide band i have a p28 with the s300 thank you
rg1721
Re: high comrpession f23 base map?setup help
Post by rg1721 »
Hey you would wire in the wideband into either one of the sensors ground (to wideband ground ) the 0-5v wire on the wideband wil goto d14 or d10 .
Don't use D14 as it cannot see the full voltage range.
