Nitrous Installation
CivicVTi
Post by CivicVTi »
I will use the power steering input (the sideeffect is that the idle does not get higher when you turn the steering wheel) and the purge control solenoid as an output for the nitrous solenoid. My question is:
I locate the cable corresponding to the PCS right near the ECU. If I cut this cable and connect it to the nitrous solenoid, obviously the PCS will not operate. What is the side effect of this? No purge control valve anymore? What exactly does the PCS?
CivicVTi
Post by CivicVTi »
So, noone is running nitrous with s200 here?
CivicVTi
Post by CivicVTi »
Hondata experts, I need some help fast. I am just about to get a dry kit and I want to know first
CivicVTi
Post by CivicVTi »
up
purge control is only for emissions and will not adversly affect the car.
