Kpro wont recognize ignition on
kirstinb17
Post by kirstinb17 »
Hi, i have a 2002 Honda Civic ex. I kswapped it for a k24 and am using KPro4 for it. The issue is that it is not recognizing that the ignition is on and keeps saying “Ignition off”. It is online and it will crank, but that is about how far it will get, it does not start. Im thinking it is not getting fuel, but unsure. Any suggestions?
Re: Kpro wont recognize ignition on
You should try the ECU in a known working vehicle and see if it reads the ignition on. If it does then there is a wiring problem in your vehicle that needs to be corrected.
kirstinb17
Is there any other possible options? I don't have anyone that I know of that has kpro where I could test it on their car.
You should try to find someone locally to test this with as it will tell you immediately where the problem is.
