flashpro 2015 si datalog help
Ryan2015si
Post by Ryan2015si »
Hey everyone new here! I got this 2015 civic si about a month ago and it came with a takeda stage 2 intake, header with a high flow cat (unsure of brand), takeda cat back exhaust and a throttle body spacer. The car has the flash pro Civicsi-2012-2014-2maftune on it I believe. I did a 18 minute datalog and was wondering if I could get an experts opinion on how well its running. I know its defiantly running rich and I'm thinking the cam angles aren't set right either.. I could be wrong though. In that 18 minute window it only recorded 2 knock counts as well. the outside temp was -3 so fairly cold outside when data log was recorded not sure if that info is needed. If I could get some feedback from someone that would be awesome !
CalibratEd
Re: flashpro 2015 si datalog help
Post by CalibratEd »
Ryan2015si wrote: Sat Feb 10, 2024 9:38 am Hey everyone new here! I got this 2015 civic si about a month ago and it came with a takeda stage 2 intake, header with a high flow cat (unsure of brand), takeda cat back exhaust and a throttle body spacer. The car has the flash pro Civicsi-2012-2014-2maftune on it I believe. I did a 18 minute datalog and was wondering if I could get an experts opinion on how well its running. I know its defiantly running rich and I'm thinking the cam angles aren't set right either.. I could be wrong though. In that 18 minute window it only recorded 2 knock counts as well. the outside temp was -3 so fairly cold outside when data log was recorded not sure if that info is needed. If I could get some feedback from someone that would be awesome !
Welcome to the forum,
Post the calibration file as well. I can take a look at it when you post the calibration file.
-Ed
Instagram: calibrated.tuning
Ryan2015si
Hey Ed! sorry for the late reply. I bought the car with the flashpro and the previous owner told me he has installed the maf tune that comes with the program.. that was probably a year ago so I'm trying to get my hands on a laptop so I can try and pull the calibration from the ecu to make sure I send you the right one. Should have my hands on a laptop by tomorrow! I appreciate the help and the warm welcome !
CalibratEd
Ryan2015si wrote: Tue Feb 13, 2024 2:28 pm Hey Ed! sorry for the late reply. I bought the car with the flashpro and the previous owner told me he has installed the maf tune that comes with the program.. that was probably a year ago so I'm trying to get my hands on a laptop so I can try and pull the calibration from the ecu to make sure I send you the right one. Should have my hands on a laptop by tomorrow! I appreciate the help and the warm welcome !
I do not believe you can pull the calibration file from the ECU. You might have to reach out to the owner and as for a more detailed description of the calibration file used.
- Ed
CalibratEd
At a quick glance, I can tell you that the car is running rich and has a bit of knock.
- Ed
Ryan2015si
Hey Ed. Thanks for the info ! If that’s the case and I can’t pull the map from the ecu I’ll upload the maf tune and do a another datalog and post both files here for you! If your a tuner and we’re willing to help me out with a decent street tune I’ll compensate you for your time! This Saturday I’ll upload the new calibration and another log. Because I know the last owner doesn’t know anything about it I already reached out. Told me it’s just the maf tune that comes with the program. I’ll post here again Saturday with both files. Cheers!
CalibratEd
Ryan2015si wrote: Thu Feb 15, 2024 11:42 am Hey Ed. Thanks for the info ! If that’s the case and I can’t pull the map from the ecu I’ll upload the maf tune and do a another datalog and post both files here for you! If your a tuner and we’re willing to help me out with a decent street tune I’ll compensate you for your time! This Saturday I’ll upload the new calibration and another log. Because I know the last owner doesn’t know anything about it I already reached out. Told me it’s just the maf tune that comes with the program. I’ll post here again Saturday with both files. Cheers!
Sounds good.
-Ed
