Cold start
Delight22
Cold start
Post by Delight22 »
Is it normal for my car to start at 1500rpm then rise to 2k rpm a second later? Is there any way I could adjust it so I can make my car start a 2k without it having to rise?
Re: Cold start
What vehicle are you referring to?
Does it do this stock?
Delight22
Re: Cold start
Post by Delight22 »
I have a 8th gen civic si and it didn’t but once I added a basemap that’s when it started
Re: Cold start
If you go to the online menu and return to stock does it do the same thing on a cold start?
Delight22
Re: Cold start
Post by Delight22 »
I reflashed it to stock yesterday and it did the same thing. I heard that it was normal for it to do that but I just wanna know how to adjust the jump start rpm if possible
Re: Cold start
You shouldn't try to change that from normal it does it for a reason.
