ECUmaster base map help
I have a K24 fitted to a TVR Vixen with an ECUmaster Classic. The engine will start but won’t run or idle. It’s been static timed to the red mark on the crank pulley. Does anyone have any experience with this ECU make and can help with setting up the base map.
Re: ECUmaster base map help
Engine now running and idling 😁
- CalibratEd
- Contact:
ChristianGrebe
Hi,
I am running a K20A with a EMU Black. Do you still need some help? You can download KManager and look for a K24 calibration but things in the EMU Classic are a lot different (VE tables vs. Pulse Width tables, a lot more tables for different cam angles in KManager).
Christian
Christian
