Active tuning not working
Hammond97
Post by Hammond97 »
Hi guys,
I was hoping one of you can point me in the right direction as to why my active tuning doesn't seem to be working. I believe I have set the parameters up properly but it never makes any adjustments, when looking at the suggested lambda values it should be making changes. I have attached my calibration file and a screenshot of the active tuning/target lambda settings below.
Any tips/advice regarding my tune would also be greatly appreciated! I'm still learning but the car seems to drive nicely with good AFR's just wanted to get my fueling tables smoothed out a bit.
Cheers
fn2 Tune 18 active tuning.fpcal
Re: Active tuning not working
Are you trying to actively tune the AFM or the fuel tables?
Hammond97
Post by Hammond97 »
The fuel tables using the 'active tuning' function under fuel on the calibration menu, if I understand it correctly it should make adjustments to my fuel table based on the target lambda values? Sounds like it will save me a lot of time rather than data logging and making adjustments manually
Are you following the instructions at: https://hondata.com/help/flashpro/activ ... sub=active
