Locking fnew flashpro over hondata reflaahed oem ecu
ef9b16a1
Post by ef9b16a1 »
Hello
Euro fn2 has one of tje hondata early reflashed ecus..
I ttird to lock a new flashpro to remap the car , i thought it would overwrite the tune or consider it the stock one to save .
I am getting tmessages ,that it may not be able to complete ans then i d have to send ecu and flashpro to hondata , should i proceed or we must find a virgin oem ecu?
Thank you
ef9b16a1
Re: Locking fnew flashpro over hondata reflaahed oem ecu
Post by ef9b16a1 »
If i go to a honda dealer and he tries to reflash the hondata ecu with oem file would it work? And then he d have to programm the immo again also i guess , since now it is off
ef9b16a1
Post by ef9b16a1 »
ef9b16a1
Post by ef9b16a1 »
I will do it tommorow when the customer comea back to know wjat works or not for the next time i one across the issue , but i ll likely put a oem ecu becaise he lives 300km away and dkesnt have time for testing.
If it helps we flash the usdm civic si ecu (for boost control) with the international flashpro version with no problems , and i see in this topic they have tried this before , but i dont see them mentioning any warning messages , but the 2010 era waa the race cal era for fn2 so that may be the case
viewtopic.php?t=11437
