k24 miata vss
Charliek4sure
k24 miata vss
Post by Charliek4sure »
1994 Mazda Miata
2006 k24a2
1994 miata 5 speed trans
02 rsx base engine harness
K power sub harness
PND Kpro v4 4.5.8.0
Help if possible. My speedometer on gauge cluster works fine, cause its a cable that goes to tranny to gauge cluster. I would like Kpro to be able to read vss but how would i go about it?
I am thinking if i use the digital Vss in kpro board and wire that red vss wire to the grn/red on pin 2f on miata cluster, and go to the setting in kpro and check box alternate speed input and enter the correct pulse, I should be good? or should i put a pull resistor between the wires? any help would be appreciated.
I also contact K power and they said to ask ya cause they don't know.
thanks
Re: k24 miata vss
What is the full part number of your ECU?
