K20/k24 flash pro map help
Mikeyaka23
Post by Mikeyaka23 »
I got a 2008 civic 8th gen k20/k24 build that I just started for the first time today with a 410cc file found on forums by EFICU. It started and idled nice but I turned off the car because I still need to install the rest of my exhaust.
Anyone can help with a map for my setup below?
My build list:
K20z3 head with k24a bottom end
Drag cartel 3.2 camshafts
K20z3 cam gears I believe they’re 50 vtc
95lb springs and retainers
72mm k tuned throttle body
3 inch short ram cold air intake
K tuned headers
3 inch rev9 exhaust
4 piston Rsx type s oil pump
410cc OEM rdx injextors
340lph fuel pump
CalibratEd
Re: K20/k24 flash pro map help
Post by CalibratEd »
Mikeyaka23 wrote: Sun Mar 03, 2024 4:20 pm I got a 2008 civic 8th gen k20/k24 build that I just started for the first time today with a 410cc file found on forums by EFICU. It started and idled nice but I turned off the car because I still need to install the rest of my exhaust.
My build list:
K tuned headers
3 inch rev9 exhaust
340lph fuel pump
Welcome to the forum,
If you got the car to idle with one of EFICU's calibrations files then I suggest you dial in the fuel and timing to make sure its running safe until you get properly tuned.
- Ed
Instagram: calibrated.tuning
Mikeyaka23
Hello Ed,
The calibration file I found searching through the forum posts was set up for an 8th gen SI with a j37 throttle body, Hybrid Cold air intake, and 410cc injectors.
And it seems to start the car fine as the first start-up after completing the engine build. I have the file I am using that I found attached to the post. Can you help with dialing in the fuel and timing?
My setup is:
K tuned headers
3 inch rev9 exhaust
340lph fuel pump
CalibratEd
I can take a look at it when I have time. Post a datalog of normal driving.
-Ed
