Ecu in recovery mode won’t reflash
Notlowgio1
Post by Notlowgio1 »
So I got my hondata for the first time and very normally I was excited to reflash my car with the base hondata reflash. Mid reflash mis stopped for the first time I due to my battery that was basically dead and being held on by a maintainer at around 11.6v or so, long story short my ECU has been in recovery mode for like 3 weeks now I’ve tried throwing a different battery( not new) and using a jump
Pack with and a maintainer and once me and my buddy got it to load to about 98% and then it dropped. My Ecu is litteraly blank I’m pretty sure because I can’t unmarry hondata it says it doesn’t read the vin but it appears in the history. I know my Ecu still
Works bc I can use obd2 and a check engine light still appears in accessory mode so I don’t know what to do, I will continue to try and see what happened but I need help!!!!
It says to check my obd2 pins every time it stops but I’m not moving and my Obd2 plug works I use. My scanner no issue
I have the hondata Mini
Re: Ecu in recovery mode won’t reflash
Notlowgio1
Will do
Notlowgio1
Spunkster wrote: Mon Mar 04, 2024 11:28 am With everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
just did it please help me out
What is the serial number? People send us the feedback all the time so we need something to be able to match it up.
check your email for the response.
Notlowgio1
Hondata wrote: Thu Mar 07, 2024 4:23 pm What is the serial number? People send us the feedback all the time so we need something to be able to match it up.
FP-2012Si-320316 is my serial number I sent a response to yours and more feedback got a new battery tried what was told same issue I need help
replied via email
