Custom Sensor for AIM Dash
jtrue
Post by jtrue »
I have 3 sensors on analog channels that I'd like to setup to read in the AIM dash, emap, boost pressure, and fuel pressure. I need help calculating the multiplier and offset for the three sensors in AIM Racestudio. I've read a couple threads, but not grasping what I need to do. Thanks!
emap is AEM sensor 30-2130-50
Settings in Kpro
Min voltage .5 volts
Min Pressure -1.01 bar
Max voltage 4.5 volts
Max pressure 2.48 bar
boost and fuel pressure sensor is Honeywell MIPAN2XX100PSAAX
Settings in Kpro
Min voltage 0 volts
Min Pressure 0 bar
Max pressure 6.89 bar
jtrue
Re: Custom Sensor for AIM Dash
Post by jtrue »
Correction, the Honeywell sensors should start at .5 volts. For some reason the sensors aren't working in Kpro, I've triple checked my wiring, the sensors are receiving 5 volts from the ECU. What's strange is that when I rename the sensors and then create a new value on the display tab in Kpro the name doesn't pop up when I scroll down to analog inputs, however they do show up for the 3 other sensors I had setup previously. Any help would be appreciated. Thanks!
Boost and fuel pressure sensor is Honeywell MIPAN2XX100PSAAX
Settings in Kpro
Min Pressure 0 bar
Post the calibration and a datalog showing the issue.
