Need a base map for my 8th Gen civic SI with a k24a with bolt ons
Finishing up my swap in the next day on my 8th Gen an wondering if some one can help me with a base map so I can start the car an possibly help me with a more in depth tune after car is running. Stock 24a with skunk 2 intake manifold aem Short ram. Test pipe to a Nvidia cat back exhaust.
- CalibratEd
- Contact:
Re: Need a base map for my 8th Gen civic SI with a k24a with bolt ons
Welcome to the forum,
There should be a base calibration in the 8th gen section of the forum. You would have to look over the threads. Give it a try and see how it runs. Post the calibration file with a datalog and I can take a look at it.
- Ed
- Ed
Instagram: calibrated.tuning
will do thanks sry for the late replay swap is done tho an will put the base map on tomorrow after work
- CalibratEd
- Contact:
Sounds good.zallen92 wrote: Mon Mar 11, 2024 6:32 pm will do thanks sry for the late replay swap is done tho an will put the base map on tomorrow after work
-Ed
had some stuff come up an found a few things i need to fix on the car goin to get that fixed then ill get back to you should be able to get done asap but worse case car should be all good an ready to go by this weekend.
- CalibratEd
- Contact:
No problem.zallen92 wrote: Tue Mar 12, 2024 6:28 pm had some stuff come up an found a few things i need to fix on the car goin to get that fixed then ill get back to you should be able to get done asap but worse case car should be all good an ready to go by this weekend.
-Ed
sry took forever lol map i used and logg from it
- CalibratEd
- Contact:
The fuel needed some minor adjustments. No knock was present which is good. You should be ok to normal drive the car until you get properly tuned. Do not drive the car hard.
-Ed
-Ed
