NC/NS
cam589bail985
NC/NS
Post by cam589bail985 »
Vehicle is a 2013 scion FRS, it has been k20a2 swapped (not by me)
ECU: kpro4 37820-PNF-A12, SN# 214283-4208
It has a turbo, aem air/fuel, oil, and boost sensors, the battery/rad fan is switched, the fuel pump is switched
The Kpro came in the car when i acquired it
The vehicle was running pretty well and as i was rolling it suddenly died, when i pulled the codes all it came back with was a p0563 system high voltage
Verified fuel pressure and tried to verify spark but there is no power to the coils, neither the trigger wire or straight 12v. I have only driven the car maybe 200 miles since i bought it but it has unfortunately been too long to try and get my money back so im stuck trying to figure this out. vehicle will still crank, oil and boost gauges react.
Appreciate any help! Thank you!:)
Re: NC/NS
You need to try the ECU in a known working vehicle and see if it works. If it doesn't then something in your vehicle has damaged the ECU. If it does work, then there is most likely a wiring problem in your vehicle.
