starter issue 98 integra
ibarra1557
Post by ibarra1557 »
Desmoines iowa 98 ingetgra gs with b18c1 swap Needing some help maybe someone has had this problem and found a solution, ive done alot of reasearch tried a few things and no luck still. My car does not start sometimes when i turn the key i hear a click down by my left foot and if i keep turning the key it will start sometimes and other times not at all so i will have to go under hood and jump the solenoid to start car. i replaced main relay switch and i have another starter but i dont know if its the starter since the jumper bypass gets the car going it was also swapped from auto to manual but i already did all the bs and hooked my reverse lights up and got cruise control working but thats spotty sometimes to. thanks for all of your help
Re: starter issue 98 integra
It sounds like there is most likely a wiring issue that needs to be addressed.
