Disable VTC enable Ethanol
toadmode
Post by toadmode »
Hello,
I have a 2008 Si (Canadian) with K24/K20 all motor. I have stage 4 cams with 1mm over intake valves so I also went with Skunk2's intake cam gear. So, I would like to disable VTC within Flashpro, which seems to only be an option within race calibrations. I also have Siri Moto's flex fuel kit and would like to enable ethanol tuning, which seems to only be an option in non-race calibrations.
Would ignoring the VTC being active and its tables cause CEL or other issues? Could I set all of the tables to zero to mitigate these possible issues? Or would they arise when the VTC attempts its cleaning cycle and gets an improper cam angle reading?
Is there a way to have ethanol tuning on race calibrations?
Re: Disable VTC enable Ethanol
Race calibrations are no longer supported and new features are not added to them.
As for adding VTC disable you will have to ask for that in the requests section.
Setting the tables to zero will not protect it from the cleaning cycle.
toadmode
Post by toadmode »
Okay cool, thank you. Where can I find this request section?
Never mind, I found it. Thanks again
