Hondata S300 v3 isn’t being recognized by any laptop
enrique
Post by enrique »
Hello,
I’ve had reaccuring issues with my s300 not connecting to Smanager, it lights up green indicating it’s getting power. And then the laptop pops up with unknown usb device windows error code 43.
Re: Hondata S300 v3 isn’t being recognized by any laptop
enrique
Post by enrique »
geometry dash scratch
I am using Hondata Version 3 and serial number is s300-11,762
What are the lights doing on the s300 board when the ignition is turned on?
enrique
Post by enrique »
The s300 green light goes out when ignition is turned on
It sounds like the ECU may not be powering up as it should. Have the capacitors been replaced on the ECU?
