Hondata tune problems
lylechin
Post by lylechin »
Hello,
Anyone having issues with their hondata after the 4.0.7 update? I havent had an issue with it since i first bought it and now after the update my 19 R will start and idle for a moment 10-15 sec or less then die. When it dies it also smells flooded. And has thrown a rev match error and emission system error. The specific code was P0101 which is a maf sensor code.
Tune is just a base 93 octane with prl hvi stock for a prl street maf and the stock maf sensor, prl turbo inlet pipe, prl down pipe with high flow cat, invidia gemini 400 full system to include the front pipe. Only additions are to disable the rev hang and go full power in 1st and 2nd improved throttle. I have also tried a couple trial tunes to include checking the sensor box to adjust the maf voltage and clear the P0101 code but nothing has worked. The hondata is the race version as well.
Any recommendations or fixes that someone has come across or found with this type of issue?
lylechin
Re: Hondata tune problems
Post by lylechin »
lylechin wrote: Thu Mar 28, 2024 2:14 am Hello,
Anyone having issues with their hondata after the 4.0.7 update? I havent had an issue with it since i first bought it and now after the update my 19 R will start and idle for a moment 10-15 sec or less then die. When it dies it also smells flooded. And has thrown a rev match error and emission system error. The specific code was P0101 which is a maf sensor code.uno online
No answer? I'm trying to find the solution
That version of software is over a year old and you should use the most recent version of software.
lylechin
Post by lylechin »
My problem was solved after I updated new version. Thanks for your advice
