Flash failed
William.Y
Flash failed
Post by William.Y »
JDM Type R FL5 , with Flash Pro Mini
Failed notice during data was flashing
FP Manager version: 4.2.3.0
Engine is not running and connection of OBD is fine
Re: Flash failed
Have you tried uploading again?
William.Y
Re: Flash failed
Post by William.Y »
Sure, I tried couple of times, same result.
Re: Flash failed
What is your FlashPro serial number?
William.Y
Re: Flash failed
Post by William.Y »
Here is the S/N: FP-CTR-INT-371829
Re: Flash failed
Has the ECU been jailbroken?
