22+Civic SI multi-tune not retaining tune selection
Civic 2016+ 1.5 Turbo
jonathanbx89
Post by jonathanbx89 »
multi-tune not retaining tune selection even after update 4.2.4 , selected tune still does not retain i am now on the most recent update 4.2.5
even than still having the same issue , has this happen to anyone else on here ?
Re: 22+Civic SI multi-tune not retaining tune selection
How exactly are you determining this?
jonathanbx89
determine what exactly ?
i updated the firmware than checked after to see if it actually updated and it did beucase the versions match on my computer and my flash pro as well
How are you determining that the multi-tune is not working correctly?
jonathanbx89
mutil tune works but it doesnt save that last map selected because every time i turn my car on its back on map 1 after setting it to map 4 prior to turning off vehicle , i spoke to my tuner (phearable) a month ago they reached out to hondata about the issue ,they told me that hondata said the fix would be on the next update, update was released car is still doing the same thing
Awsomsauce
Post by Awsomsauce »
I’ve brought this up before and recently have again. Still waiting for answers.
Previously the person complaining of this was not actually uploading the calibration to the ECU.
Awsomsauce
So is there still not going to be an answer as to what is supposed to be done because the multi tune feature isn’t working and is being superseded by the quick selectable boost by gear tab.
We're investigating. Please keep to one thread.
