im working on a d16y7 turbo build that has the following.
scat rods, vitara pistons, 550 cc fic injectors, 4 bar speed factory map, y8 intake.
i have my wideband gauge and everything to help with a tune and get it dialed in just right. i'm only going for 15 to 20 psi due to wanting it reliable and i'm actually using it for a gridlife build. i need a base map to start off of i'm running the p72 ecu with the v3 i've gotten it pretty good for the most part just want someone with a little more knowledge and experience to help me out if able. after gridlife i have a b18 turbo build i plan on putting in it as well that's built for boost so i plan on coming back and asking for the advice then as well is anyone able to help me out ill send a file of my tune for you to look out
d16y7 turbo build
Nickbrian24
d16y7 turbo build
- CalibratEd
- Contact:
Re: d16y7 turbo build
Post the calibration file and I can take a look at it.
-Ed
-Ed
Instagram: calibrated.tuning
Nickbrian24
Posted the tune file with the post and thank you
- CalibratEd
- Contact:
