Accord 2018 2.0t - Stays at 14.7:1 afr when WOT
Speedbust_r
Post by Speedbust_r »
Hi,
At full throttle, when "Use AFM to determine WOT" is unchecked, ECU stays in closed loop until MAP reaches 14psi approx. Is there a way to get the ECU to determine WOT sooner/quicker?
CalibratEd
Re: Accord 2018 2.0t - Stays at 14.7:1 afr when WOT
Post by CalibratEd »
Post the calibration file and a datalog. I can take a look at it.
-Ed
Instagram: calibrated.tuning
Speedbust_r
Thank you!!!
CalibratEd
I am still learning about this platform. Try adjusting the WOT determination table. To my understanding, The table houses the airflow needed to deem wot at that rpm. If you want open loop sooner I would lower the value and test it.
-Ed
Speedbust_r
OK, thank you! I will try to modify the WOT determination table this weekend.
