Laptop Cant Read from Hondata
Posted: Tue Apr 09, 2024 6:02 pm
by Skaterforeva1
Hello! I purchased a P28 ecu with a Hondata V3 online. I am using an eBay jumper harness to hook into my 1998 Honda Civic EX. It has a B20b swap. When I hook my laptop in, I am not getting any signal from the ignition or motor. It says online but I do not have a lighting bolt to upload/download tunes even when the key is on. I can crank the car over a couple times and get a check engine light for the O2 sensor I left out. Could it be an issue with my laptop to the Hondata? Or could it be something with my eBay jumper harness? Im stumped. I checked all my grounds and replaced one. Any info would be greatly appreciated.
Re: Laptop Cant Read from Hondata
Posted: Wed Apr 10, 2024 8:53 am
Post a picture of the adapter harness showing where it is plugged in on both ends.
Posted: Tue Apr 16, 2024 2:37 pm
by Skaterforeva1
Im not sure how to make the pictures show up here.
Posted: Tue Apr 16, 2024 2:49 pm
Post pictures of the soldering on the bottom of the ECU that was done for the s300.
Posted: Thu Apr 18, 2024 5:05 pm
by Skaterforeva1
123
Posted: Fri Apr 19, 2024 8:56 am
Is J12 cut on the ECU?
Have you replaced the capacitors on the ECU?
https://hondata.com/accessories/capacit ... uage=en-gb
Posted: Fri Apr 19, 2024 12:08 pm
by Skaterforeva1
Yes J12 is cut. When I first got the ECU I sent it to Burton racing where they confirmed the ecu was working. They also said a capacitor was leaking so they put new ones in.
Posted: Fri Apr 19, 2024 4:09 pm
Was it tested with the s300 in it by them after replacing the caps?
Posted: Tue Sep 24, 2024 6:36 pm
by Skaterforeva1
Problem is solved. I used a cheap ebay jumper harness. Once I ordered a jumper from speed factory racing. I could upload/download tunes and everything worked properly.
Moral is I lost 3 years of progress due to a cheap ebay purchase. Don't be cheap on your builds.
