Removing RSX/DC5 stock cluster/dash with Kpro-V4.
CHB
Post by CHB »
Hi Hondata,
I am planning to remove my stock gauge cluster on my DC5. Currently it has a perfectly running Hondata Kpro V4.
What are the parameters I need to reconfigure in the Kmanager so it will function as per normal?
Re: Removing RSX/DC5 stock cluster/dash with Kpro-V4.
Why are you removing the cluster?
CHB
Post by CHB »
I'll be fitting a roll cage with no dashboard.
The stock cluster is a bit of a odd shape to fit onto the the cage structure too.
Currently have an OBD2 smaller compact dash with sequential shift light.
CHB
Post by CHB »
My other question is, does Kpro4 needs any signal from the stock cluster?
No it does not.
