FlashProManager 4.2.6
FlashProManager 4.2.6 (10 Apr 2024)
• Firmware updated to version 241
• Improve Bluetooth reliability
• [FK8] Added second PA ratio table (A34,E13,E23,E34,G12,J13,U12,U23 binaries).
• [FL5] Added 66V-K02 ECU.
Download here
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
Special note for the PA table added to some FK8. The second turbo ratio table by PA is only used under some circumstances related to temperature. Our recommendation is to make this table the same as the normal PA table when tuning a new calibration. When revising an existing calibration if the ECU uses the second table then care must be taken so that boost does not increase a lot - this applies to those who choose to set all the ratio tables to the maximum ratio of 6 (which we do not recommend). In any case it is best to set the maximum boost pressure value to limit boost (to something less than 5.12 bar).
