Base map for DC5 with bolt on mods and cams
llckll
Post by llckll »
HI All,
I keep asking my tuner for my MAP file and even offered to pay for it but crickets.
With that said, I'm considering using a base map just so that I can calibrate my TPS which I don't want to do but not sure if I have a choice.
Current mods:
DC5 K20a (eg6)
CAI
Skunk2 TB
Skunk2 IM
Skunk2 Cams
Ktuned Header
Lightweight Pulleys
2.5" Exhaust
I have another thread open on K20a.org where I was experiencing idling and driving issues but since has smoothed that out after replacing the spark plugs and ignition coils.
I calibrated the Acuity TPS to .48v when fully closed.
When I try to WOT when RPMs are under 3k RPM it goes into limp mode.
When I gradually accelerate, I am able to go past 3k RPM and drive normally.
Anyone here have similar mods and can share MAP file or recommend a base?
Thank you in advance.
CalibratEd
Re: Base map for DC5 with bolt on mods and cams
Post by CalibratEd »
Is there any reason you are running the Acuity TPS? I have had a similar issue with a remote tune. The guy reverted back to an OEM TPS and all was fine after that.
-Ed
Instagram: calibrated.tuning
