2013 Civic Si Stage 1
Josey Wales
Hello all. I recently bought a 2013 Civic Si which was stock except for K-Tuned SRI. I purchased an Acuity Curl Control CAI and a Flashpro. I installed the CAI, then babied it home. My plan is to get a DP with high flow cat, then eventually an intake manifold. My first flash totally transformed the car. My only concerns were the first cold start caused a brief engine rattle, the first log revealed 16 knocks on a 30 mile trip with mixed driving(although it was all mild driving). Also first gear is a little jumpy.
My first datalog looking for knocks.
Thanks for looking
Thanks for looking
Josey Wales
Re: 2013 Civic Si Stage 1
Here's my Calibration file:
- CalibratEd
- Contact:
The MAF needed minor adjustments. I reduced timing where knock was present. Create another normal drive log. I want to confirm my changes took effect.
- Ed
- Ed
Instagram: calibrated.tuning
Josey Wales
On it. Thanks Ed
- CalibratEd
- Contact:
Josey Wales
Same drive. Only going the other direction.
- CalibratEd
- Contact:
- Ed
- Ed
Josey Wales
Thank you, Sir. Here ya go, Ed
- CalibratEd
- Contact:
Only a few counts of knock left. Create a similar log.
- Ed
- Ed
Josey Wales
I created a new log, but the file was too big. I will make another after it stops raining. I tried to highlight half of it and save, but couldn't figure out to save that portion of it
Josey Wales
Zero knocks until a did a hard pull to pass a truck. Then 16 knocks in 2 seconds. Oops
- CalibratEd
- Contact:
Modifications I have made are to make it run safe for normal driving only. Don't drive the car hard.Josey Wales wrote: Thu Apr 18, 2024 1:20 pm Zero knocks until a did a hard pull to pass a truck. Then 16 knocks in 2 seconds. Oops
To shorten the log, right click at the point where you want to cut it and select set new end the save the log.
- Ed
Josey Wales
Thank you. I'll make a note of that. Meanwhile, I made another run.
- CalibratEd
- Contact:
I cleaned up a few counts of knock. Create another normal drive log.
- Ed
- Ed
Josey Wales
I did have a momentarily lapse of judgement. Realized it immediately.
Make note; Datalog was done on 87 octane. Let me know if you need another log instead.
