FlashPro Manager adjusting all tables? Bug? (v 4.2.6)
katch22
Post by katch22 »
Howdy all,
I am struggling with something that might be a bug, or might be user error. When I go to adjust any value in the fuel or timing tables, any of the keyboard shortcuts to adjust values (CTRL+I/CTRL+D) or the right-click "adjust value" dialog adjust that MAP/RPM value across all cam angles for that low/high cam setting.
For example: if I go to the low fuel table, cam angle 0, and select the top-left cell, then press CTRL+I, all of the values in cam angles 15,30,40,and 45 are also adjusted by the same interval. It has been ~6 months since I did any tuning, but I thought I remember the shortcut or adjustment windows only affecting the cam angle I have selected, not all the cam angles.
I have tried the options "Tables follow VTEC" and "Tables follow cam angle", both on and off, but they do not seem to have an effect.
Any thoughts or advice would be appreciated! This is happening in 4.2.6, but was also happening in 4.2.3.
Re: FlashPro Manager adjusting all tables? Bug? (v 4.2.6)
What vehicle are you referring to?
katch22
Post by katch22 »
Spunkster wrote: Mon Apr 15, 2024 2:06 pm What vehicle are you referring to?
Sorry, this is a USDM FA5/09 Civic Si
Do you have the "all" button selected at the top of the table?
katch22
Post by katch22 »
Spunkster wrote: Mon Apr 15, 2024 2:40 pm Do you have the "all" button selected at the top of the table?
That's precisely the problem. Thank you so much! I was certain it was user error, haha.
