Launch RPM Ign Retard
dvergara
Post by dvergara »
Hi Hontada, can you help me with a problem. I have a 2012 civic SI and I am trying to make negative time when I launch but the ing always goes to zero and not negative
The car is a 2012 civic si, FIC 650 CC injectors.. RBC manifold
Here I send you a datalog and the map
Re: Launch RPM Ign Retard
The ECU cannot make the ignition go negative.
dvergara
Post by dvergara »
Is it something particular to this ecu? .. on the 8th Gen and the Kpro I am doing it. Is there any parameter that can be modified to make time negative?
The ECUs are all different and do things differently.
dvergara
Post by dvergara »
Hello Honda. Can you give me a better answer? Before I could make a 9th gen can do -10 ignition and now it is not possible
We can give you a correct answer but apologize is that is not the answer you want.
